Help me please! ISC not working
joeym4130
296
Dec 8, 2003
philly, Pennsylvania
What could cause my ISC not to engage???
It is a good ISC, and I tried it with 2 to the same result. I use my logger to check and see its always at 0% and idling high.
Upon starting the car the ISC engages itself for a short time. Thats when it stalls its weird...let me try to explain.
I drive for a bit to get it to op temperature. Then i shut it off. When i start it back up, it will stall and accoording to the log, my ISC is moving. I have to stab the gas a few times to keep it alive, and it will stay alive at 1900RPMs as an idle speed, but the ISC is then not engaged. It stays at 0% and idles at that high RPM, so when my ISC does work its only upon starting the car warm and causes stalling....WTF should i check guys, any ideas??!?
Anyone? :cry: I checked the ISC again, ran voltage to it and it moved when applied so i kno its good, resistances check out too, no vac leaks either! AHH!!
This crap must be contagious. Mine isn't having any of the symptoms, but it is crackling at the plug, so it is probably going. I hate this crap.
Well the problem isnt that the ISC is bad, its that its not engaging!!!! I am trying to figure out, under what conditions would the ISC be told not to do anything by the ECU, so far i know idle position switch and ECU. My idle position switch tests good, ECU i would assume good, no problems w/ car otherwise and looks good onthe circuitboard. Anything else could be messing up the ISC???? :confused:
crankbender, funny you ask that. When i got the car, the coolant lines to the TB were pulled, and it idled high. I called the guy up and asked why and he said the FIAV went bad, so he took them out and redid the coolant lines. I took the TB off and made a gasket from a can and RTV'ed it over the FIAV outlet, and I think it worked because if its cold out it will stall from no cold idle :rolleyes: but hopefully i can get a new TB and redo it all this summer. Like if its cold, i have to hold the gas in until warm, then once it starts to warm up, the idle goes higher and higher until full temps and idles at 1900, and ISC isnt moving at all.....
