Help me identify these cams!
stjoetalon
67
Jun 3, 2002
St Joe, Missouri
I recently purchased a 1g turbo head and these cams were in it. I need to identify what exactly these are!
Both cams stamped with "EP4804"
On the exhaust cam, there is also a cWC and E11, and C2 stamped on them. On the part of the cam that you can put a wrench on...one flat is market "546" and the next is marked "601"
On the intake cam on the same spot is "547" and "601"
I tried to look around the web for answers and called RRE. No luck thus far. Does any of you know how to help?
EDIT:
Thanks kahl23! Your google skills own mine!
I found out that these were WEB street grind cams. Just in case someone else needs help!
