Help indentify these cams
matt98eclipse
1,078
Aug 15, 2006
mesa, Arizona
Hey guys i have a buddy of mine that has this cams installed in his car. The car sounds no were near like my 1g gsx with 272's. His car has a pretty decient lope in it so were thinkin his car has a set of aftermarket cams.... Anyone know witch cams these are?
Based on the second to last picture with the "F" on the cam I would guess stock cams, or possibly regrinds. The "F" is a factory grind designation and have seen "A, B, C, D, and F" cast into many 4G63 cams over the yaers.
Aftermarket cam manufacturers typically do not cast identifiers into their cams, as most use common engine specific blanks to grind a specific profiles to, and then identify them via a custom grind number, like 546/547, 264/272, or XYZABC.
If these cams are an aftermarket set you will need to look more closely for a series of numbers on a flat or machined pad somewhere on the cams.
Thanks bud. Ill check it out and see if i can find anything else.. My bc 272 cams sound nowhere near what this sound like. They have alot bigger of a lope in them. The car does a nice steady idle, has good compression, and timing is all right! So im not sure:ohdamn:
