help i'm scared!!!!
selmerguy
1,810
23
Nov 14, 2004
Killeen, Texas
hey i read some posts and people were talking about fuel problems with a turbo kit. now i will put my custom kit on next week and i have a 255 fuel pump and a vortec 12:1 fmu. i plan on running about 6psi on a t3 untill i build my motor up. i should'nt have any fuel problems should i?
No way, you shuoldnt have any at all. Stock injectors are supposed to work up to 7 or 8 psi... But if your that worried, than buy some 30lb injectors and then you will have PLENTY of room to spare! Just dont go out and beat it up! As long as you take good care of it and keep it maintained, you sholdnt have any problems for a LONG time . Good Luck :thumb:
Yeah, go for it! Our stock 190cc injectors will be good up to 8psi with a 12:1 rising rate fmu :dsm:
baxsom said:
arent the stock injectors 235cc
No, stock injectors are 190cc. They can handle up to 8psi but no more otherwise the pistons and rings will cook.
s t o c k i n j e c t o r s a r e 1 9 0 c c
28psi pushes stock at 190cc, 43psi pushes 235cc. the more pressure you put to injectors the more they will push out. Mitsu made it so the fuel system would only need 190cc.
