Help fuel system
Junior98gsx
May 4, 2010
Fort Worth, Texas
okay currently i have no fuel upgrades on my 2g 420a turbo
running 5psi of boost
I have a cheap knock off aeromotive fpr from eBay already hooked up but useless because of the stock fpr by the tank
but i just order the aeromotive fpr 1:1 from summit & 6an lines, i should receive it in a day
problem is can this setup work for my car? Ive searched and seen people needing to get a fmu 12:1
My idea is: My Walbro GSS342>6an hose>russell fuel filter>6an hose>aeromotive fpr>to steel line going to the fuel rail
okay will this work or should i return all the stuff back?:banghead:
I'm planning to run more than 8psi in future
Do you have any means of increasing the injector pulsewidth (i.e. MegaSquirt)? Or do you have some other way to add additional fuel (i.e. Hahn's PortFueler)? If not, your proposed fuel system won't work very well... you need a 12:1 FMU to add the appropriate amount of fuel under boost.
FO sho .. I had afc with 1:1 afpr and wideband and every pull would be different on a wideband.. I got it to run around 11psi and couldnt do anything more.
Oh okay cool,well i guess ill order the vortech 6z110-111 12:1 FMU
One more thing i guess im going need a fcd? Will the HKS type K3 FCD work on eclipse? or which kind should i get?
