Help fuel pump wont prime
dre1189
Nov 20, 2009
Hboro, New Jersey
I have had a problem with my car starting. I took it to a shop and i had them check it out and they said it was a fuel pump gone bad. i changed the pump and it worked until i got to the gas station when it died again. the fuel pump now will not prime just as it was not before i changed the pump and filter. i tested the pump with a wire from the battery to see if it even works and it works. i thought it might be the fuel pump relay so i bought a new one from the dealer and replaced that and it still will not work. can someone please help me i cannot figure out what else it could be. the car is 1999 eclipse rs. any input would be greatly appreciated.
