1g dsmlink v3 fuel pump prime?
but
190
Apr 7, 2009
Ridgecrest, California
I was curious if you can prime the fuel pump with dsmlink v3 on a 1g? I cant find where to do it if you can.
You can turn the pump on and off but I'm not sure there is a setting to "prime" the pump everytime you start the ECU.
If the fuel system is working correctly the normal pump starts when you begin cranking will pressurize the system right away.
Ok thankyou for all the help i will look for it. I wanted to set the fuel pressure before I start the car on a fresh build.
