help finding an o2 housing that dumps
speedyred85
Sep 13, 2007
Houston, Texas
i've looked around but im having trouble finding an o2 sensor housing that dumps into the atmosphere...if anyone knows any websites thanx, but if it becomes too tedious then i'd rather just go with o2 eliminator dp that dumps
i'm getting a VRS turbo back 3" from the housing...i want to get the two together (02 housing and exhaust) and make sure everything bolts right...so far the ones i've found like the EVO III o2 housing is only 2.5" does the dp that comes with the exhaust have a 2.5" end that bolts on or do i have to get a fitting i've read some threads from people who have a VRS so if you know i could use the advice thanx
I have never seen a 3inch o2 housing on a mitsubishi turbo unless your running some other kinda turbo but the vrs turbo back system that your getting should come whit a 2.5 flange on it then open up to a 3inch that's how mine works..
SSautochrome makes them in dumped and recirced versions. I had the dumped one and absolutely hated it. I wish I would have gotten the recirced. PM me if you want mine.
I'm running the ssac recirc. one and it works good, "after I had the flange machined."
I've read some people get luck and don't have to get machine work done, I wasn't that lucky.:mad:
BTW, expect some unneeded attention from your local police.
^^^He aint kiddin:)
"i've looked around but im having trouble finding an o2 sensor housing that dumps into the atmosphere"
You must be kiddin' me. Usually it's the other way around. Trying to find a housing that is recirculated is a much more difficult search.
It's already been said, but you could just about go down your list of bookmarked DSM websites and find one at every other, if not nearly every, DSM shop. We're not gonna do the work for ya, bud.
On the other hand, if you need help deciding, I'm sure everyone would be glad to give you their opinion.
The outlet of the turbine housing is only 2.5", why would you want to step up to 3" so suddenly? You're going to have a hard time finding a decently-priced 3" o2 housing WITHOUT a dump, let alone one with a dump.
I would go with Punishment racigng/O2 housings/,but it is up to you.I am also runing on my car VRS exhaust,but i have Full 3" DP from the housing.They just sent me the DP without welding the flange to the O2 housing,so i had to do it myself to get the right angle.I am also using evo3 O2 housing,which i had to port a little bit,because the way my turbo's hot side is made.It is a little bigger than 2.5",so i ported both sides and it gets really big.It maches perfectly the 3" DP flange.
