HELP Failed Emissions
daltah
516
Sep 27, 2002
phoenix, Arizona
I solved the rpm problem when it kept bouncing I disconnected the safc2 and it stoped when trying to hold the rpms at 2k. I failed now because hydrocarbons were too high and running too rich. The fuel pressure is around 40-42psi at idle with the vac hose connected. The bov was vented from when i bought it off of LR2TSIAWD. Im going to recirculate it and put in new spark plugs. If anyone else can help with any suggestions I would appreciate it.
daltah said:
I solved the rpm problem when it kept bouncing I disconnected the safc2 and it stoped when trying to hold the rpms at 2k. I failed now because hydrocarbons were to high and running to rich. The fuel pressure is around 40-42psi at idle with the vac hose connected. The bov was vented from when i bought it off of LR2TSIAWD. Im going to recirculate it and put in new spark plugs. If anyone else can help with any suggestions I would appreciate it.
How's your o2 sensor? Also, take a look at your catalytic converter, it may be shot.
Search the forum too for some fuel additives that can help for your emissions as well.
Yeh. We tell you and tell you and tell you people not to vent. :beatentodeath:
Give the ECU a couple of weeks' running to get its shit back together after you correct the error.
