failed emissions????
2GturboTALON
607
6
Nov 26, 2002
St. Peters, Missouri
SO the car i recently purchased just failed emissions. What im wondering is can fuel system cleaner in your tank cause you to fail. I mixed it in when i got a half tank of gas and tested witha about a quarter left. It was Redline fuel system cleaner. Any suggestions?
here are the readings
My readings
Hydrocarbons - -- Carbon monoxide --- Oxides of nitrogen
(10.8502 ) ( 113.6841 ) ( 5.9865 )
Standard
(0.8000 ) ( 15.0000) ( 2.0000 )
Is your mod list up-to-date? You might just want to check for boost leaks that might be causing you to run rich if you're still running intake/exhaust.
