2G Help broke the recirculation piece off my bov
Corve
Mar 3, 2019
Westerville, Ohio
Hi I have a 97 eclipse it has been sitting for a while had some other issues which I know how to fix but the one I dont is I broke off the little recirculation piece off my stock plastic bov I dont really have time or money to do anything custom atm I cant seem to find one that is a direct fit I put a piece from autozone that made it not run like total shit but it's still leaking does anyone know where I can find a stock one or one that I can install relatively easily I have like $40 I can spend on it all the ones I've been finding are like $250 I have found others without the recirculation valve but idk if that works relatively new to turbos here eventually I want to pull the motor and rebuild it but for right now I just need it on the road
The bypass valve you will be looking for is from the Evo 8/9. The MR Evo 8 had the metal ones, and all Evo 9's had the metal valve as well. Other models of the Evo 8 had a plastic one, which is not what You want. You can get them used here, EBay, and on Evolution M forums for around $60-80. If you're after a new one, many of the supporting vendors have them available.
Part # 1545A001
You could also go with a 1g style, but will need an adapter to work using an OE configuration.
