Help What broke?
srodgers1342
Jan 27, 2011
Hampstead, Maryland
So i was driving home tonight coming up to a red light, pushed the clutch in and heard something snap, not very loud. my clutch pedal went to the floor and sat there. i have some pics, sorry if they are crappy its dark and they are from my cell phone. I think its the clutch fork and master cylinder? But i owuld like somone to confirm this or tell me otherwise.
Thanks.
well your clutch fork is broken for sure, as its non existent LOL.
and that slave cylinder will need to be replaced too
I can't tell extremely well due to the pics. But from what I can see your Slave cylinder blew apart and your shift fork appears to be broken off. How hard were you pushing down on the clutch? Doesn't seem likely that your clutch fork broke under normal conditions, perhaps it was already cracked, but I would check things out in the trans when it's pulled as that really shouldn't happen.
so i gotta find a clutch fork, get a new slave cylinder, and then pull the trans to fix it? And i wasnt pushing down very hard or anything. just taking the car out of gear for the red light
Yep, I'd also replace the TOB (throw out bearing) with a new OEM one while you're in there. The clutch fork can't be replaced without pulling the trans. I'd also take a look and make sure nothing was binding up in there or that there wasn't anything wrong with/broken on your clutch because as I said I don't think that happened from casual driving without something wrong.
The forks are prone to cracking and breaking with an aftermarket clutch...
Parts list for you:
New Clutch Fork - EXTREME PSI : Your #1 Source for In Stock Performance Parts
New Pivot Ball - EXTREME PSI : Your #1 Source for In Stock Performance Parts
New TOB - EXTREME PSI : Your #1 Source for In Stock Performance Parts
New Slave Cyl - EXTREME PSI : Your #1 Source for In Stock Performance Parts
Tranny Fluid MT90 - EXTREME PSI : Your #1 Source for In Stock Performance Parts
Brake Fluid - AutoZone It
So without counting brake fluid, you're looking at $260 if you order from Extreme PSI. Here is all the info you'll need to perform the job:
General Instruction - 1G AWD Clutch install
Slave Cyl - Slave Cylinder for the Clutch
Clutch Adjustment - Clutch Adjustment
Pivot Ball Info (Something to consider) - TRE TECH TIPS
Sorry to hear about the bad news, its not a difficult fix but does require pulling the tranny as others have mentioned. With the help from a friend you should be able to get the job done in 1 day depending on your skills.
