HELP asap with DSMLINK install!!
rock0134
69
Dec 16, 2007
Superior, Wisconsin
I just hooked up the 95 eprom ecu and swapped the plug order and hooked the cable up to the obd port and to my laptop it said it recognized new hardware but it will not connect. The key is turned on and when I open DSMLINK and click on "online" under ECU it says IO command failed....
Please help me I am very frustrated.
where in link do you switch that?? I have it in the right most usb port... Thanks for the quick responses
Awesome I found it under options I changed it to comm9 and it worked! Thanks then chip is burned for 880's and I am still stock (got 850's for next weekends project) so I'm going to try to set the global and deadtime for that and get it to idle. Does anyone know offhand what global and deadtime you use for stock?
Idled good, I adjusted it up and down and it was working.. I set the rev limiter and 3 and 4 thousand rpm and it worked (I don't have the cc wire hooked up yet) and I made a few logs of the car at idle and just revving.
I would take it for a drive but it is dark and rain/snowing. I just got the car out of storage today and changed oil, plugs, tranny fluid, and diff fluid... along with a can of seafoam through the bov vacuum line and a can through the gas. Doing it through the vacuum line smoked the shit out of my whole neighborhood!
