heats not working, engine studdering.
Make sure the knob is switching from cold to hot. See if you can tell a difference in the temp when on cold vs hot.
Also check both heater hoses with the car at operating temp. Both hoses should be hot. If 1 is hot and the other is not the chances are the heater core is clogged.
check your coolant level, first thing you need to do when no heat is coming from the heater core is check coolant. The heater core bypass valve would be the next guess, along with a clogged heater core which is kinda difficult to accomplish.
