headlight?
^^Do this first^^
Then...
By normal running light, with your description of everything, I'm assuming you mean the low-beam light. Check your relay/ fuses for corrosion (replace as needed), and check your wiring for breaks or burn marks. Sounds like your low-beam on that side could be grounding out until you add the high-beam
  • Wanted 6 bolt NT water pipe
    • chrisman287
