Headlight Adjustment Issues
DearestNameless
308
Jan 16, 2010
Linton, Indiana
My dim on the passenger side is to far to the right. Is there a way to adjust it that I'm missing. All the bulbs are correctly seated, I've triple checked. Also the lights are perfectly level in the pictures using the center adjustment. I know there is a left and right adjustment on the ends but it isn't fixing my problem. Any ideas? Thanks tuners.
Not that I know of. The headlights are in pretty good condition. I figure maybe oxidation was causing it but there wasn't much on them and what was is gone now.
Is the radiator support where it is bolted to bent? Even a small dent in the rad support can cause the light to be that far off. You may be able to take the air box out and see if it is pushed in in that area. If not, you could try to put a washer between the light and radiator suppot to angle the light to the center a bit. Are the headlights aftermarket?
