Headgasket help!
Hey guys I just wanna give a little update I got my arp's in the mail today and headgasket from the dealership Im gonna try and get her done by this weekend! Heres some pics. Also i was totally amazed on how much crosshatch was in the cylinder walls. I think the bottem end my have been rebuilt before!
There was a thread a while back on the DSMLink forums discussing the use of copper spray on multi-layer gaskets. If I remember correctly (and I believe I do) the conclusion was that the copper inhibits the different layers from expanding at different rates, completely negating the reason for using a multi-layer gasket. I would avoid sprays when using these gaskets.
You're right, I wouldn't run an MLS all together. :cool:
I've always coppered sprayed my multi-layer hg and have never had a problem.
I've always sprayed the mitsu metal multi-layer hg and used no spray on the stock composite hg.
It's a real bi*** to remove the copper spray + stock composite material from the mating surfaces when you remove it.
ARPs torqued 100lbs + Metal mitsu multi-layer + copperspray has held 37psi & 8k rpms on an scm61 on my last talon. With head resurfaced.
So on the stock oem comp gasket i should use it and the MLS type dont use the copper spray??
goodluck.
i doubt the rebuild, mine looks the same, just good condition which is nice to know. Good choice on the ARP's, the lube is gooey! haha.
sorry to bring this up i just want to be sure. I have a fresh built block with an older built head from a previous build. I can use a stock felpro or mitsu headgasket with the stock head bolts and it will hold my 500hp goal? or do i need use arps?
You have a 1992: If you have a 7bolt, use arp headstuds and composit gasket.
If you have a 6-bolt and it is already assembled and inthe car, then push it and see. Worst case scenario is that you replace the headbolts with arp head studs after a blown head gasket. You SHOULD pull the head/headgasket if you swap in ARPs. If it's all apart now, get the ARPs.
The head was resurfaced already right? I went with an OEM because I found they hold up very well. My goals aren't 500hp, but low 11's, high 10's in the 1/4. If the block and head are resurfaced, then you might as well go with an MLS gasket, you got nothing to loose there. Don't even second guess ARP's, just get them.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
