Headers
if they are the same motor they should work...and i am not quite sure which motor is in the 3gs
not the same motor iam sure. and why not buy the ones for your car. wont the 2.0 headers fit the 2.4? if that why not wait save money and buy a turbo kit and or piece one togeather. if your buying headers your going to have an increase of like 2hp. i would not recomend it if your going for power. the money to power ratio is not that good for NA eclipse's. Its bling factor is up there yet i would want to rock more bling on a money clip then into 2hp. its up to you.
Dodge motor to Dodge motor - no, they won't. The 2.4L gets some of its increase in displacement from being a taller block.
I thought the 2.4L 2g Spyder and 3g RS motors were both mitsubishi 4g64 engines? Im not sure if the headers are the same though.
They might be. I dunno. I'm thinking they must be, as a buddy of mine here at work is using a stock 4G63T exhaust manifold and turbo on his 3G RS. :shrug
01 and up Dodge Stratus coupe, Sebring Coupe and 3g Mitsubishi Eclipse use a 2.4L 4g64 as their standard engine. There is an option for the 2.5L or 3.0L Mitsubishi V6.
Do NOT confuse the the Mitsubishi engine used in the above cars with the chrysler 2.4L used in the cloud cars.
Doug
