Header Coating Question
ZooKs
71
Feb 9, 2005
Frankfort, Kentucky
Just starting to try and restore the 95 GSX, and one of the main problems I previously had was high engine temps. Now the SS DNP header I have I wouldn't say is heat wrap friendly so been wondering if sandblasting a SS header would work and if so once that was done and the Black Satin coating material air brushed on, I have a spare can of the DEI hi-temp silicone coating, would spraying some of that on the header either/and before/after curing would help to retain its properties and longevity?
Here is a current pic of the header:
Either way, I will most likely also like to do the turbo manifold and 02 housing for extra protection.
And here is a link to the Black Satin Coating that I mentioned:
http://www.caswellplating.com/aids/techline/index.html#exhaust
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
