Header question
Ryan2ill
35
Jul 31, 2005
Cedar Rapids, Iowa
I have a 90 plymouth laser w/turbo. I was looking to buy a new header/manifold cuz the one I have has a small crack. Just wondering if this one I found on ebay is worth my money or if the design is @%##!
Thanks
4575852032
Get-r-done man it looks like a winner cheep affordable and should do the job it should help spool up time by a quite a bit. :dsm:
You have an exhaust manifold, not a header. :thumb:
Look for a 2g manifold or if you have cash get the evo III manifold.
That is a manifold. A pretty crappy one at that. Those, anything by ssautochrome or anythign fancy and shiney that's under $250.00 on ebay is not worth it. The welds don't hold and if you do buy it you have to make so many braces for it to hold it ends up looking pretty junky when you are done. Just go with a 2g ported manifold. I'm putting down a solid 350hp and it is flowing great. You can upgrade to an EVO III or Slowboy one but for the money I would stick with the 2g ported one. Can find them on ebay for under $100.00 and they don't look as fancy but they flow more than you will need.
Say no to ebay manifolds. They are junk, nothing but problems. Go ahead, buy it. You'll find out soon enough. :notgood:
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
