Powder Coating Question
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
I am going to be powder coating my valve cover that i have shaved and added AN fittings to. My question is, how well does it need to be prepped before heading out to powder coat? Will powder coat show imperfections like paint does. The reason i ask is i can see some deep sanding marks from coarse sanding on the top where the letters used to be. Should i sand this thing to a polish before hand? I believe the powder coat should be thicker than paint hiding some imperfections that you would normally see if you were going to paint. Someone with some experience please chime in and let me know what needs to be done before i take it to powder guy that way i can save some money. I've attached some pictures so you can see the sanding marks and some pitting that i'm talking about.
At shops that do powdercoating they clean and prep the part right before they shoot it with media. The scratches will not be an issue. The powdercoating bakes and flows a bit to hide them marks as long as there not goudges. The little pin holes might show thow. You could mig them then sand that flush with the rest of the VC and you will be fine.
I figured if i had all the prep work done it would save some money. You can barely feel the scratches with your fingernail so i believe they will be ok. Funny part about the little pinhols is that used to be the stock pcv ports that i had welded up and when i started sanding on them to make them look smooth that when the little holes started to show. Guess the guy doing my welding sucks. :barf: The middle picture that is on firewall side so you really won't be able to see that. But the small pitting around the bungs is right on top of the valve cover, they are much smaller so hopefully the powder will flow into them and smooth out.
  • Wanted 6 bolt NT water pipe
    • chrisman287
