Resolved Head removal
Bigmike4g63t
Supporting VIP
315
417
Apr 17, 2010
Batesville, Mississippi
I was outside working towards removing the head to take it to a machine shop today and this is what is behind the lower timing cover.
There is a significant oil leak somewhere. I guess I will see more once I remove the head.
Will I need to get piston 1 to TDC before removing the head? I have read conflicting things.
TDC or stick a long something down one of the spark tubes and rotate until you find the halfway point between tdc and bdc
Two 17mm wrenches on the cam gear bolts and squeeze them together to release tension on the belt then walk the belt off. Release slowlyish. Works better if one is a ratchet to give you extra clearance for the belt to come off and not get caught up on a wrench.
No, but you will want to set it to TDC before you put the head on and align the cam sprockets with the dowel pins up also before you place it on the block.
Solution
With the timing belt off it's one bolt to remove the tensioner pulley and off comes the BS belt. The balance shafts/belt have nothing to do with the head; it's all contained in the block/front case/oil pump.
