Resolved 2G headlight removal trouble
603CRIT
45
Jan 18, 2011
newmarket, New Hampshire
I have searched but have not found an answer all my searching is talking about the bolt under the headlight which I have removed and is not the problem.
I have the 3 bolts out and for some reason the headlight wont come free on the fender side. is there a trick to get the headlight out? I have tried everything and it just wont come free I don't want to pull to hard for fear of breaking something.
also does anyone know off the top of their head what the thread size is on the bolt for the top of the headlight unfortunately when I tried to loosen the bolt the head snapped off due to rust so I'm gonna need to drill and tap it out
Just the headlight itself or the whole bucket with track? The headlight should only be 2 long screws an a spring, maybe 2 springs and the wire
sorry I should have said this .... this is for a 97 gsx
I figured it out.... it was the harness plug for the headlight that was holding it on
This may help
Solution
I had all the bolts it was the plug that was catching on the bumper
Does the bumper cover have to be removed/loosened? I'm trying to figure out passenger-side headlight removal on 99 GS. The top bolt is the easiest and most obvious. What to do from there?
