Head Bolt Washers
raysdsm
Nov 4, 2009
Bristol, West Virginia
OK here's the question...
After installing my rebuilt engine into my car (1G) I then realized I installed the head bolts without the washers. The question is since the engine has not been started can i replace the washers by removing the head bolts one at a time, It is a MLS gasket... Thanks!!!
Are they head studs or bolts? If they are studs, you wont be able to get all the washers on.. Some of them wont clear the valve springs, you have to install the washers befor you slide the head down the studs..
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
