Having Problem with Big 16g
joaquin_johnson
Aug 14, 2005
Glendale, Arizona
Hey everybody,
I have a 92 Eagle Talon TSi Automatic. I just brought a 16g and my coolant lines don't fit the turbo. Do I need 14b lines and banjo nuts to fit my turbo? I believe that the old turbo was a 13g, do the 14b and the 13g have different coolant lines to the turbo?:talon:
If you are an automatic, then yes you will need different lines. The automatic's had shorter lines to make up the difference on the smaller turbo. The lines that need changed will be the water lines, and I would suggest changing the oil feed and return as well.
