Big problem with engine
Tigerhorns
381
Apr 6, 2010
Aiken, South Carolina
Heres a link to one of my recent post lots of videos, and pictures so you can get a idea of what ive been going through http://www.dsmtuners.com/forums/newbie-forum/380689-bad-idle.html
YouTube - SAM 1478
When i did my boost leak test air was comming through my dipstick when i pulled it up. Thats not good is it?
YouTube - SAM 1473
Check out my crappy bov connection shoot some tips on what to do with that LOL.
I did this post to get my old thread off of page 3 i want people to see it i want advice HELPS
First problem is there a a seal on that Biss Screw, just unscrew it out all the way and replace the seal... no big deal. Just be carefull, they are very easy to strip...
Second problem, I would say to replace your PCV valve, when they go bad they put a nice amount of pressure into your VC... hope this helps man... gl. A proper PCV will also help prevent oil into your IC pipes.
One way to check the PCV valve is to take it off and blow into it. If it doesn't close its no good, when you go and buy one, I recommend getting a second one for back up as they tend to go bad easily.
