turbotom
- 120
- 42
- Sep 27, 2003
New Bedford,
Massachusetts
Ok I finally got this 2g running after MIA for too long.
The car has:
stock 6 bolt swap
b16g
680cc, PTE injectors
3 inch turbo exhaust with high flow cat
fmic
ECMLink v3lite
ported 2g exhaust manifold
tial 38mm WG
2g MAS
AEM WB
etc....
The will idle lean at idle like 17.9AF, if I compensate it will get better but run super rich which in meaning no happy medium. Now when cruising, it stumbles, pops, farts and goes peg lean!!!if I add 40% - 60% it will go like a bastard but in WOT it does the same thing. After a run or 2, then it gets so bad you have to shut the car down, wait 10 seconds start the car again, and it's able to cruise some what and then repeat itself. I calibrated the wideband, TPS is adjusted, base timing is perfect, using BR7ES plugs, new wires, and new fuel filter. No matter what I did, nothing changes.
NEED HELP!!!! I miss driving this car but hate the way it runs.
I made a log but for the life of me, I have no clue how and it's driving me crazy,
The car has:
stock 6 bolt swap
b16g
fmic
ECMLink v3lite
tial 38mm WG
2g MAS
AEM WB
etc....
