has anyone experienced this?
terminaltsi
309
Dec 16, 2001
louisville, Kentucky
while under load and over 4500 rpm, i get a severe stutter. i also notice the EGT's dramatically drop to about 450*C while this is happening. at first i thought it was too rich, so i leaned it out some witht he SAFC, but then i found my knock to be rising when i had none before.i tried very small increment, but nothing seems to smooth it out.
i'm running a 255, 650 inj., afpr, safc for tuning.
any ideas?
Thousands of poeple have experienced this ;) Typically a stutter at boost worthy rpms is ignition related, and a over rich misfire/stuter will happen anytime, even reving in nuetral.
well, i have less than 5k on the plugs and wires, the plugs look like they are burning properly. will check for boost leaks today. anyone think the fuel pump might be at fault? i bought it used....
What kind of plugs? A visual inspection might miss wire issues.
terminaltsi said:
will check for boost leaks today. .
Always do this first.
Also, for the love of god, please use descriptive thread titles. The next guy with stuttering issues might not search on "experience before" when looking for a solution. :rolleyes:
ok, so , no boost leaks found. coil pack and ignitor substituted for known good parts.
plugs are new. plug wires are new.
EGT's drop to 350*C when stutter occurs, while a/f ratio drops to the lean side. that's what i don't understand. why would egt's get cold while it's running leaner? how is that possible? the typical rich running car would show a/f as rich while egt's drop.
When the motor is misfiring the air-fuel mixture isnt burning, so it doesnt get very hot ;) That could explain it. Also keep in mind that high EGTs can be from being too lean OR too rich, its not as simple as people want to make it. In fact, on diesels with high EGTs (over 1300 degrees F) you take fuel out! Or add air, or nitrous. Basically you add as much fuel as you can without going over 12-1300 degree EGTs. I also put up a lengthy post about EGTs a couple years ago.
what about the lean condition while the egt's are dropping like a rock?
You have no way to know that there is a lean condition. The O2 voltage drops because oxygen content goes up, again, the mixture isnt being burned in a misfire. In fact, thats how I spot misfires with DSMlink, downward spikes in O2 voltage (obdii loggers typically arent fast enough).
As I said before, msot likely ignition reltated misfires, all independant of fueling, and the readings from the EGT guage and O2 voltage are useless if you dont know how to interpret them. Have you tried swapping any ignition related parts like plugs (properly gapped) and wires? If not there is no point in continuing this thread. :)
Found the boost leak, looks like the coupling coming from my turbo to the ghetto IC kit I made was to close to the E. manny. Melted a hole right through it..... the funny thing is I never felt like spool time was any slower. And I still am hitting 15 psi.... :confused:
Oh, I also found a hole in my ignition wire. How that happened I have no idea. So I ordered another set of Magencore 8.5mm wires, NGK BPR6ES, and a fuel filter just for kicks! :laugh:
gotcha on the misfire.
i think i've solved it, pulled a hell of a lot of fuel out to -38% at high.
Injectors compensation alone should have you at -30-31% (650s in your vehicle profile). So you are only 7% leaner than that, which is perfectly reasonable (assuming fuel pressure, air metering, injector flow are all normal or course). For reference, I shoot for 11:1 for regular pump gas settings, which is 10-11% below injector compensation. Anyway, the point is, thats not taking out a lot of fuel, thats pretty much right where you should be for 650s. :)
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
