Hard to turn crank after installing head.
92AWDTalonTSI
334
8
Jun 2, 2010
Somonauk, Illinois
The title says it all. Installed a new head. Now the car cranks really slow. The head was out for about a week. While it was off I did turn the crank to clean the soot from the tops of the pistons. All only while the head was off. I dripped about 4-5 drops of oil in the cylinders to keep the rings lubed up a bit. Only once was the crank turned in the wrong direction (Past TDC a bit while cranking.).
Now that everything is installed it struggles very hard to turn over. As if something is binding up. Upon installing the timing belt the crank was TDC, oil pump was spun till it rested timed and the head was in time from the get go. Once the belt went on all marks were still in proper location. Proper oil and coolant levels etc etc. It's almost like it's bound up.
If you're cranking it by hand, and the head has the spark plugs installed, then yes, it will be harder to crank because there is now compression. Take out the spark plugs and it should be easy to turn again since you aren't fighting against the compression.
I'm not fighting compression. The car turned over fine. We replaced the head because one of the valve guide seals were leaking oil into the combustion chamber. And now it won't turn over. Its been a week at most since the last time we tried. And last night after a long time wrenching on the car to get it into a startable state. Hit the key, sounds like the starter is struggling and it moves very slowly. IDK what it would be. We are going to replace the cams in the head we got with nicer condition ones. Hopefully it works.
Try turning it over by hand and see if anything is actually binding. If it spins easy, and it cranks slowly when you turn the key, it sounds like its either a starter going out or a weak battery, like mentioned above.
Car is on a charger ATM. It's hard to turn by hand. Wasn't just hours ago though. I'm sure I got timing correct. All marks lined up. It's got to be those cams. I wanted to change them out from the get go. But decided not to. :ohdamn: It's got fresh oil. There shouldn't be anything binding up...
Sounds like it.. Well since it turned over fine before, you know it has something to do with the head. Consistently tough to turn makes me think of cam journals/cam caps somehow binding. Timing belt or cam gears aren't rubbing on anything are they? Any strange noises when you try turning it over?
What was done to the new head?
I'm going to TDC the motor. Zip tie the belt to the cam gears and pop the gears off. Then remove the cams. I'll check the cam journals when I remove them. Hopefully all is well. I just don't want to take the head off again.
We put newer primed lifters and rollers in. I'm sure no vales are bent.
Ok so you primed the lifters. Im going to ask again did you bleed the oil out of the lifters before you installed them?
If not then there is a very high Probablity that you now have a bent valve or all.
Hydraulic lifters self adjust.
When you prime them out of the engine they adjust to max height.
If you dont bleed them before install then they can easily hold the valves open longer than they should when you first attempt to start the car. EVEN ON NEW PRIMED LIFTERS
When these valves are held open too long they contact pistons in many cases.
I hope your right and the valves arent bent.
Make sure your cam caps are in the correct order
When/if you take the tbelt off try and turn each cam/gear by hand and report back the difficulty.
This is where I would start as well. If those Cam Caps aren't in the proper order or over torqued you will experience exactly what you've described.
Good luck.
We used newer lifters that were in another head. The ones from the head previously on the engine. It was leaking oil into the cylinders from the valve guide seals. You could literally see the oil dripping from the center 2 exhaust side valves.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
