dsm-onster
DSM Wiseman
- 8,592
- 131
- Jul 11, 2004
Bloxom,
Virginia
I'm rebuilding my brother's engine. He bought a blown 1991 GSX and a 1991 6-bolt N/T block.
His turbo rods and pistons from the blown motor checked out quite nicely. So we swapped them into the N/T block. The N/T bearings looked very, very, so very good!!! So I kept them and installed them on to the piston rods going to their respective crank journal. I, of course, lubed everything midswap. Except for the cylinder walls. I swapped new oem rings as well.
The n/t block rods had a little play (lateral or forward-and-back: along the same line as the crank). The engine was running before I took it apart. But w/ the turbo rods installed, there is zero "lateral" play. The crank is "hard to turn" I can't turn it except w/ a wrench of significant length. . . I need quite a bit of torque. Then as I'm turning it, she becomes easier to turn over. . . Considering what I've done to this block, Is this ok? Of course w/ the head installed, it becomes a little harder to turn over, but I can still do it. Again, it gets easier after I turn it over one revolution. But if I wait a while, it becomes very difficult again (need an extension on the wrench handle).
. He wants a reliable ride for now, but something that has potential for a fun "build" in the near future.
(mine and my brothers). Anyway, I know of a reputable NAPA machine shop in salisbury, MD. This is closer to me. I'm sure they would be capable of doing what we need. . .
