hard to shift, could it be gearbox?
ninja07
51
Dec 7, 2009
antioch, Tennessee
I've got a '95 awd Talon tsi. It is fairly hard to shift into gear when sitting still. It's also a little hard to pull out of gear when sitting still. And when I'm driving and shifting, it takes it a second to shift up or down all gears...........Could this be my gearbox?
New parts:
*New oem clutch kit, w/ 11.5 lb chromoly flywheel
*reinforced clutch release fork from MachV Motorsports
*pivot ball
*Hurst short shifter
*ss steel clutch line
*new oem master & slave cylinders---------(bled and adjusted)
*brass shifter cable bushings
*nylon shifter plate bushings
Note: It was hard to shift before all the new parts, I was hoping these parts would improve the shifting, but it has made no difference, except a shorter shift throw...Oh, and the car has 180k miles on it. Any advice would be great, thanks....
New stuff, no leaks. I park on a very light gray driveway and have put 1000 miles on it since new stuff, and no evidence of leakage. The clutch was adjusted at install and was re-checked twice after a few hundred miles. No fluid level drop at the master. All fluids are new.
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
