2G Hard coolant lines?
Atlantian
5+ Year Contributor
38
4
Jan 13, 2018
Erie, Colorado
Sorry guys been looking everywhere for an image of where the small hard coolant line bolts to on a 95/96 GSX block. Couldn't find a good image if there already is one, I do have the manual but it's very vague as to where I'm supposed to bolt it.I know where the hose ends are supposed to go & i think the upper tab bolts to the bigger water pipe but not 100% sure.If anyone has a good image or could explain where I'm supposed to bolt it up, I'd be very grateful. Thanks.
Yea I'm at work but I'll get one for you later. I believe I have a pic of the diagram & the part number on the pic. Ya its number 8 on the diagram!
I understand it's not from the block but it has 2 tabs that bolt to the block to secure it! I'm just trying to figure out where I'm supposed to bolt it on the block!
It goes from the oil cooler to the water fill housing!
Cool that helps for the bottom mount, thanks! Now does anyone know where the upper tab bolts to?
I actually found that pic earlier but cant find the complete pic of that hose, I suppose does it even matter where I secure it?
Awesome actually that first thread shows where the upper tab bolts down & it's to the little bracket on the big water pipe as I suspected. You cant really see it because it's under that rubber hose. At any rate I'll take a pic and throw it on here later just incase someone else needs it, just cause it's hard to see. I got it out of a junkyard and didn't take it apart. That's why I wasn't sure where to bolt it! Thanks so much.
Definitely the oil cooler line. The other goes to the coolant pipe.
That’s it. Looks perfect to me. Invest in some decent hoses and clamps.
