all black 4G63
5+ Year Contributor
278
51
Aug 5, 2019
Chicago, Illinois
Just wanted to check if anyone knows the fuel level voltages for a stock 1G AWD fuel tank and sender when trying to calibrate the IC7 dash. Sorry I’m trying to take the easy way out here..I’m looking for “empty” and “full” voltages
Thanks
The 1G FSM lists the resistance for the Fuel Sender as 3 +- 2 ohms when full and 110 +- 7 ohms empty.
You'll have to do the math to find the voltage after the voltage drop across the resistance. Ohms law applies here.
Voltage/Amps=Resistance - Ohms Law
Thanks Steve! :cool:
LOL Thanks, unfortunately this will not work because when the sender is all the way down at 110 ohms that would be a dry tank (no reserve). I’m trying to calibrate the Haltech dash preventing myself from completely filling it. But it’s ok I’ll just have to do that since I’m not finding the quick answer. I’ll post the measurements after I do it so the next guy can save time.
So here are the values for anyone trying to calibrate an IC7 dash fuel level in a 1G AWD with a stock tank and a stock fuel level sender:
First will be measurements with the stock dash and sender plugged in: EMPTY
Empty (please see photo for reference of Empty).
-Measured at the sender with stock dash plugged in, vehicle running @ 14.3V charging, fuel level sender reads 4.38V
-With the motor off and stock DSM dash plugged in resistance is 34.5Ω
-With the motor off and the stock dash unplugged resistance reads 85Ω
With the IC7 Plugged in, engine running, empty fuel tank, voltage on (AVI4- 240Ω pull up) reads 1.21v
With the engine running and with a full tank of gas (~13 GAL) voltage on AVI4 reads .003v
With IC7 plugged in motor off - 1.8Ω measured at sender.
I hope this helps someone calibrate their IC7 dash.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
