hall effect cas???
l2yanE
Feb 5, 2006
Front Royal , Virginia
since were trying to not have the random misfire problem and will be using the ecu + from mach v- so were can i get the hall effect sensor?? and if its a stock part what car do i order if for???:confused:
The hall effect type (black top) cam angle sensor came on 93-94 4g63 powered cars (both turbo and N/T).
The Mitsubishi part number is: MD184529
You would probably be better off finding one in a local junkyard, eBay, or in the classifieds.
Also, it is NOT a cure for random misfire; it just supposed to have higher resolution and use similar technology as the 2g sensors.
