BOV Setting Effect MPG?
flipnoy213
145
Mar 23, 2004
Stockton, California
Will having BOV set on hard or soft effect gas mileage? :confused: If it does at what setting will i save gas?
the only way that i think it can affect gas consumption is if you are venting without a blow through, or vps set up.:thumbdown I hope that helps:talon:
Venting might, otherwise no it wouldn't...if you are venting your ECU expects the air to be returned, if it isn't you'll essentially have more fuel than air...but even then I don't think it affects MPG.
  • Wanted 6 bolt NT water pipe
    • chrisman287
