haha very noobish question
Craigthenormal
Apr 1, 2004
Pinckney, Michigan
a bov on a fwd 1g turbo auto, what does it release at? i installed a mbc and i cant get my boost over 8psi. is there a problem with the mbc, or can the tiny turbo not put out any more than this, or is the the actuator?
how do you know? you have a boost gauge?
well anyways thoughts... from what I know, the 1g BOV is fine for boosting near 20 psi... I say maybe check your vacuum hoses.
The BOV wouldn't release at 8 psi anyways. It only opens when you let off the throttle, or you exceed it's capabilities. (cetrainly not 8 psi on a 1g BOV) The stock "boost gague" is horribly innacurate anyways, so you need an aftermarket one. If you still can't get over 8 psi, you either installed the MBC wrong, or you have a boost leak. Or what he said. ^^^.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
