very noobish question (re: clutch fluid)
HSK
365
Nov 21, 2003
Orange County, California
i think i have a leak in my clutch fluid.
where can i add more clutch fluid?
i cant find the clutch fluid cup.
its a tiny little cylinder in the upper driver side corner under the hood. Just use a screw driver and pop off the cap and fill it back up. I suggest you check if the slave cylinder is leaking or not. Change that and change to a ss clutch line and everything will be fine.
Close the hood. Pay a mechanic. You'll wind up saving money.
But, since I know full-well you won't listen:
^^^ hahaha, thats where its at, but check in your car near the clutch pedal. See if there is any leaking into the car. If your fluid levels are dropping, take the car to a mechanic asap to get that slave/master cylinder swapped out. If not you might find your clutch stuck to the floor one of these times.
Defiant you're truly a "different" individual. But heres a question...
Since you feel like you're leaking fluid, give us an idea of how you came to this conclusion please. Like whats going wrong or what is happening?
thanks for your help.
my clutch was starting to stick. i forget when it started. tried turning left and it didnt stick, so praying that it isnt crankwalk.
this weekend i am gonna go under there check out if its leaking and most likely its leaking. i am actually just having it changed by my friend who is a machanic.
i tried looking for the clutch fluid (knew that it would be place either right next or under the break fluid, but i wasnt sure so i wanted to double check in the forum) didnt know how to ask the question since it was so noobish.
*i also saw where the clutch fluid was on 1gs, but i wasnt too sure on 2gs, just trying to be safe*
thanks again
:thumb:
