h8 standalone ecu ignition order
zcoh2gdsm
646
4
May 13, 2011
harrisburg, Pennsylvania
just picked one up, i plan on installing it tonight, i have a tactrix cable, evoscan and romraider, now the only part im confused on is installing it. i can swap out the ecu fine, but if i install it, the only thing i need to change is the coil positions correct? i dont have to swap the pins on the ecu?
can someone show me the proper setup for the coil switch? i've looked but couldn't find a diagram anywhere.
