GVR4 fuel pump Q's
Kasprzap
Dec 16, 2006
DP, Illinois
Are the galant vr4 fuel pumps different than a 1g turbo? I want to possibly swap in my stock fuel pump from my 92 gsx into one and want to know if it will work. Also, can you install a new pump the same way as a 1g or is it in a differnt spot?
The fuel pumps between the Galant VR4 and 1G turbo are the same. The sending assembly is different, so you'll need to swap the pump only. The sending unit is in the trunk on the driver's side.
