Guys with aftermarket fuel pressure regulators
firebirdvert305
387
8
Mar 6, 2005
Davenport, Florida
Just out of curiosity, if your running an aftermarket fuel pressure regulator, what size vac hose are you using for your boost reference port? I think I might have too small of a line (3/16 vac line) causing fuel delivery issues over 25psi. Let me know if you guys are using 1/4 or bigger, thanks.
What's your fuel pressure under boost? Does your fuel pressure drop when you get over 25psi??
I don't think a single Bosch 044 And 1450s with enough especially with e85.
How do you know that isn't enough fuel, he didn't even say what his setup is. He could be on a 16g for all we know.
My fuel system is
Twin intank walbros 255s
Kenne bell boost a pump running at 18v
Fic2150s
-8 feed/stock return
Russell fuel filter
Oem rail with -8 adapters
Weldon fpr
Car runs e85 only boost is 40psi...base fuel pressure is 43.
I ran a tiny -3AN line to mine and had no issues. The I.D. is .14", which is smaller yet than your 3/16" hose.
My pressure starts to drop off erraticly around 25psi. Im wondering if the 3/16 hose is holding me back.
