2G GSX rear suspension part numbers
Yes they can get a lot of oem parts lots of parts needed, read the threads here for how to and parts, it should really help seeing things go together.
IS IT POSSIBLE FOR PART NUMBERS FOR THE FOLLOWING
ALL PART ARE FROM GSX
Transmission
Transfer case
Front axles
Drive shaft
Exhaust
Fuel tank and shield
Rear subframe
Rear axles
Rear differential
Swaybar
Rear knuckles
E-brake cables
AWD Flywheel
AWD fuel tank connectors
AWD subframe rear bolts
AWD drive shaft and exhaust brackets
Entire AWD rear suspension assembly
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
