1G required maintenance part numbers
arbiter
159
Jul 21, 2008
Irun, Europe
I am planing a full maintenance on my gsx.
I am aware that some sellers on the states, sell oem parts quite well and for a very nice price, but I want to get a quote at the local mitsubishi dealer. However, they don't have the adequate software in order to give me part numbers for such a task.
I have found that the following parts are need in order to make a whole belt maintence. Could it be possible to get these a matching part number ?
- Timing belt
- Balance shaft belt
- Timing Tensioner
- Water pump
- Timing belt tensioner pulley
- Balance shaft tensioner pulley
- Idler pulley
- Crank seal
- Oil pump seal
- Balance shaft seal
- 2 Cam seals
Thank you in advance for your time and wisdow.
I am planing a full maintenance on my GSX.
I have found that the following parts are needed in order to maintain it. Could it be possible to get these a matching part number?
- Timing belt - MD326059
- Balance shaft belt - MR984778
- Timing Tensioner - MD164533 (6 bolt) or MD308586 (7 bolt)
- Water pump kit - MD972052
- Timing belt tensioner pulley - MD129355
- Balance shaft tensioner pulley - MD115976
- Idler pulley - MD121933 (6 bolt) or MD156604 (7 bolt)
- Front Crank seal - MD343563
- Oil pump seal - MD365697
- Balance shaft seal - Not sure what you're looking for
- 2 Cam seals - MD133317
See part numbers above.
This is not 6 bolt or 7 bolt. 604 is a supercession part number. The early 90 cars had a longer bolt and the idler pulley had a flat surface. The superceeded part number is deeper and requires a shorter bolt. They are interchangeable with the correct bolt. I don't even think the earlier part number exists anymore.
got a quote from local satan dealer.
- Timing belt - MD326059 91.10€
- Balance shaft belt - MR984778 49.70€
- Timing Tensioner - MD164533 138.38€
- Water pump kit - MD972052 187.58€
- Timing belt tensioner pulley - MD129355 53.81€
- Balance shaft tensioner pulley - MD115976 44.49€
- Idler pulley - MD156604 49.71€
- Front Crank seal - MD343563 16.50€
- Oil pump seal - MD365697 14.15€
- 2x Cam seal - MD133317 10.66€
I think it's a bit expensive. a really expensive quotation.
1€ = $1.28
