1990AWD
Supporting VIP
- 8,541
- 27
- Apr 27, 2009
Langham,
SK, Canada
All feedback is appreciated.
The car is a '90 Eclipse GSR-4 5spd.
GOALS:
~400whp daily driver on 91 pump
looking to be able to go to the strip a few times a year, also looking for decent handling, but nothing major (someday when I get a 2g, then I'll worry about handling more)
From the saying, "Cheap, reliable, fast - choose two", I choose reliable and fast, but at the same time am going to try and put my money to best used, so most parts will be bought used.
ENGINE:
the bottom end only has 80k original kms so unless I come upon a bunch of spare cash, it will have to do.
new OEM headgasket and ARP studs
272/272 cams (brand?)
new timing components and water pump
oil port mods (head and OFH)
minor head port
EVO VIII valvetrain
BSE
ARP rod and main bolts
TURBO & EXHAUST:
FP 68HTA
FP race manifold
EVO III O2 housing
3" Megan Racing O2-back exhaust (already installed)
FUEL SYSTEM:
Walbro 255LPH
new lines from fuel filter to rail
950cc+ injectors
Aeromotive AFPR
INTAKE:
Dejon intake pipe
PR FMIC
1g crushed BOV
DRIVETRAIN:
Fidanza flywheel
ACT 2600 PP
ACT street disc w/ solid hub
4 bolt LSD rear
SUSPENSION:
over time, all bushings will be replaced
Megan Racing coilovers
front strut tower bar
RM racing sway bars
ENGINE MANAGEMENT & GAUGES:
ECMLink V3 w/ SD
Eprom ECU
Innovative LC-1 wideband
Autometer boost, temp, oil pressure and temp
MISC:
I'm keeping the a/c but deleting power steering
battery relocation to trunk
if a Saturn alternator fits in the stock location, I'll do that
Missing anything? Help me fill in the blanks
GOALS:
ENGINE:
minor head port
EVO VIII valvetrain
BSE
TURBO & EXHAUST:
FP 68HTA
FP race manifold
EVO III O2 housing
FUEL SYSTEM:
Walbro 255LPH
950cc+ injectors
Aeromotive AFPR
INTAKE:
Dejon intake pipe
PR FMIC
1g crushed BOV
DRIVETRAIN:
Fidanza flywheel
ACT 2600 PP
4 bolt LSD rear
SUSPENSION:
RM racing sway bars
ECMLink V3 w/ SD
Eprom ECU
MISC:
You got everything else covered ,,with that turbo u should make around 400 no problem..maybe look into a COP setup there not that expensive ne more. :h
