grinding into 3rd and fourth
eclipsemustang
110
Nov 15, 2005
suburbs, Minnesota
so i was driving the other day and decided to do a little WOT driving so i floored it through 1st and 2nd but as i tried to shift into 3rd gear all it would do is grind so i then tried to put it into 4th but that would just grind as well so as last resort i put it into 5th and it went in just fine, it will also go back into 2nd just fine. this doesnt happen all the time though its only happend to me twice but both were in the last month, i was wondering if anyone knew what was wrong? maybe the synchro's or clutch or transmission. althought a new clutch and transmission were just put in 10,000 miles ago. any help would be great
Well depends, were you trying to shift at high RPM's, like around 7000? if not and you were just casually driving your synchro's might be shitty or/and your shift fork might be bent
same thing happens to me with 3rd gear sometimes. im just gonna swap in some syncromesh and not worry too much about it b/c i hardly "get on it"
Clutch, trans, DRIVER? Try going all out through 1st, 2nd, then letting out the clutch in neutral, then putting it in 3rd. kinda like double clutching, but slowing down the trans, not speeding it up. be your own synchro. :thumb: then you can elimate that as a possible prob. Does this happen every time you rip through 1st and 2nd?
