dnhieu
- 1,927
- 17
- Aug 16, 2004
panama city,
Florida
for my motor rebuild i bought a diamond star motorsport oil cooler kit to be used with my 90s oil filter housing. before i put the motor in the car i thought i would figure a way i can get this thing mounted. so the first persons gallery i thought of looking at was yours because of the good pics you had in it. well i mounted my oil cooler in almost the the same exact way you did! after thinking about this a good while i was "crap how is this going to work with when i change my oil every 3k miles the oil cannot come out of the oil cooler the way it is mounted unless the oil pump is pushing it through". should i go ahead and figure out a way so i can mount it upside down? i was curious if you had any problems with this or you just dont care because you change your oil so often that their is always clean oil in it. i will be using this mainly as a daily driver and probably be changing my oil every 1.5 to 2k. unlike you who changes your oil way more often then that.
thanks alot
david
thanks alot
david
Well, I won't be doing mine like that. There's just no way to deny that the oil won't be contaminated and that it's gonna be left in there. He might be doing it and not have a problem. Many people drive there car 1,000's of miles before doing an oil change and not have a problem. Not that it's good for the motor though. Sure, ya might not see a problem...till it stops running. Can ya actually see metal particles floating around in the motor as it's running? Nope. Just because he hasn't had a problem "yet" doesn't mean it's not doing harm. Just because "X" person does it, doesn't mean I'm always gonna follow. But it's not my motor that'll be done like that so it's not really my concern. To each his own I guess
