Greddy RZ BOV vacuum nipple replacement?
xxNocturnalxx
698
12
Nov 5, 2011
Tacomptan, Washington
Like the title states, the vacuum barb on my RZ is broken, I've tried the Greddy knock off ones with no luck suprisingly. Anyone know where I can get a replacement?
If you can figure out the thread size then you should be able to pick up a new nipple fitting from a local hardware store.
Just so everyone knows, its going to be metric. I tried to find one for my old Type-S, never did.
heh, I didnt even think of it maybe being metric. We don't run as many BSPT pipe threads, and do not have them online.
Still though take the fitting out and get some measurements and figure out what pipe thread you are working with.
If you still cannot find the part once you know what you're working with maybe you could re-tap the hole to a more common pipe thread and use a diffirent sized fitting. :D
Alright, thanks for the info guys. 99gst_racer I'm sure the type S is the same as long as it's not the knock off, did you happen to find one laying around, I'd be happy to take it off your hands:cool:
Also, I cannot get the thread size for a while as the car is not with me.
