Vacuum Nipple Help?
Kyogie12
306
Feb 14, 2010
Boulder, Colorado
Can anyone tell me what the nipple in the middle of the intake manifold should go to? It's to the right of the line going to the valve cover if that helps. I don't have a working camera so i can't take a picture.
thanks!
Hmmm okay. I forgot to mention it's on my 1g, i haven't updated my profile with it yet.
I think i have my boost controller set up wrong then...maybe you guys can help me out?
So i have a hose coming from under the battery, then BOV dump i've got down. Should the MBC be before or after the BOV? Could you just lay down how i should have it all hooked up? Thanks!
To properly hook up your boost controller, use the information in this link; the BOV and boost controller should have no direct interaction: http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/237982-best-way-install-mbc.html
As for the hose under the battery, it is most likely an emissions line leading to/from the charcoal canister. If I remember correctly, the largest hose from the charcoal canister should plug into the stock intake pipe, but it's been a while since I removed mine that I'm not 100% certain on that. Other lines running to it (depending on year) run to the purge control valve (right next to the charcoal canister) or the evaporative emission purge solenoid (on the driver side firewall).
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
