Greddy FAT speed sensor issues
kchaazz
1,166
80
Oct 2, 2002
PENSACOLA, Florida
Okay, I cant seem to find any answers to this, so here goes.
I recently hooked my tt speed sensor wire to my ecu to play with the 0 to 100 km hr function and what not and the problem Im having first and formost is that my tt reads exactly double my actual speed. Second, my speed sensor, according to the tt, isnt working sometimes at all and this is correct becuase while my speedo cable is driving the speedo fine and there is no code on my logger for the speed sensor malfunctioning, my 5500 rpm stutter box kicks in when I hit that rpm point, moving or not. How annoying this is. Im going to see if the signal to the ecu is being degraded by the tt being hooked into the speed sensor imput on the ecu by disconnecting the tt wire and if that doesnt fix it then I suppose my reed switch in the speedo itself is malfunctioning? Anyone ever experience this problem before? Any help will be greatly appreciated.
Thx, Charles
Okay, so I disconnected the speed sensor wire from the greddy fat to my ecu and my sb still kicks in right when its supposed to but when im driving down the road, so my reed switch is f*&ed I think. Anyone ever try to replace the switch and or know where i can buy one? Im sure I can do the job but just ntk where to get the switch. I still dk why Im not getting an error code for the ecu not receiving a signal from the speed sensor though? Anyone?
