Greddy TT Ebrake and Speed sensor wires
Totaleclipse04
69
Jul 17, 2005
Wichita,, Kansas
I just instaled my Greddy full auto turbo timer. I was not able however to hook up the Ebrake and Speed sensor wires. Can you guys show me a pic or tell me in description where these to wires are located. Because i would like all the functions on the TT to work like Time attack and all that. Thanks Guys.
the speed sensor is hooked into the existing speed pin on your ecu, which is located in the passenger side within the center console. However, the e-brake line you need to tap into you just pull out the whole section that has your ash tray/cup holder. I can take a pic or two for you tomorrow afternoon if noone has by then.
i can find pin 86 thats no problem the only problem now is do i connect the ebrake wire to the one of the pins on the connector on the back of the ebrake or onto the thick black wire that sits there by its self.
Tap the wire that is by itself from the ebrake. Then before you put everyting back together test it out.
I got that done. The Ebrake thing works. Now i think i found the ECu in which i hook up to pin 86. But its a pain in the butt to get to. Can you guys post a pic of where its supposed to hook up so i know what to look for. If the Thing i found i will have to take stero out to get to it. Im talkin about the Vechile speed sensor.
