speed sensor
No, you can't use a 1g speed sensor. IT has to be from a 95-99. You can use a 95-98 galant sensor also from an auto or manual, but you will have to swap the shaft and gear from your current sensor. They are like 88 brand new at rockauto if you want a new one. I would check to make sure that the plug hasn't just came unhooked first, there is a little metal clip that holds it on that could be missing. There is one 10mm head bolt that holds the sensor in, remove that and pull it out the top. Be careful not to drop anything down the hole into the transmission or you will be pulling it apart.
Not sure if it will fit, but speed sensors are quite simple to change, usually one bolt holding them on with a connector plug on the other end. shouldn't take more than ten mins to change its that simple, and thats calculating time to jack the car up :D
It is possible that the plug is just disconnected, just find the rear transmission mount (under the intake manifold), the sensor is right in the middle of the bracket. Heres a picture of that mount, the sensor is a bit dark though. :coy:
Sometimes the top of the VSS can break, you'll want to replace it with this.
OEM Vehicle Speed Sensor: Mitsubishi Eclipse 95-99
If its the gear that needs replaced there are three different 2g VSS gears, if you need a new one here are the respective part numbers. You'll know if the gear needs replaced if the teeth are chewed up or one side of the gear is flat.
AWD M/T 95-96: MD746492
AWD A/T 95-96: MD757055
AWD M/T 97-99: MD749150
AWD A/T 97-99: MD760150
FWD M/T 95-99: MD746492
FWD A/T 95-99: MD757055​
If you decide to pull the gear out of the transmission DON'T DROP ANYTHING in the hole, including the 10mm bolt that holds the sensor in. If you drop something in there you've got to pull the transmission and open it up to get whatever you dropped in there, out.
...and you don't need to jack the car up.
:dsm:
thanks, i read that you have to take the battery out to get to it, is this true? can someone give me a little bit more descriptive detail? thanks
and its a manual transmisson.
What does this vas look like ???
Vss*
I have a bad vss, sometimes it works if the cruise control is on...
A simple google search came up with this.
how do you know the whole VSS is bad or just the gear without pulling it? i asked bc my speedo works 20% of the time..
I got mine for $79.73 from extremepsi.com mitsubishi wanted $240 good deal !
Your Mitsubishi dealer must be stupid or ripping you off.
Here's my prices. (2G AWD 5-Speed part numbers shown)
1995-1996 5-Speed Speedo Assembly (minus gear)
Part#: MD756606
List Price: $84.98
Your Price: $64.25
1995-1996 5-Speed Speedo Gear Only
Part#: MD746492
List Price: $15.33
Your Price: $11.59
1997-1999 5-Speed Speedo Assembly (minus gear)
Part#: MD749149
List Price: $74.72
Your Price: $56.49
1997-1999 5-Speed Speedo Gear Only
Part#: MD749150
List Price: $14.82
Your Price: $11.20
Any idea of what part number 2g vss sensor and gear to use to swap in a 1g awd? I don't have the factory instrument cluster. I'm running a aem ems. Thanks.
I had broke my sensor pulling my engine out. easy to break if you are not carful :ohdamn: still haven't replaced mine :( mine is a manual. and sensor looks just like this. I went to auto zone to buy a replacement and they obviously didn't have the right one. it was a huge looking sensor and I haven't gotten a new once sense. ha
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
